TSP catted y-pipe next to fuel lines!?!?!
I've installed one and yes, the drivers side cat comes very close to them and the TA.
Flipping the fuel lines - on their brackets - will help a lot. One 10mm screw holds each bracket - just take out the screws, flip the lines(counter clock-wise from the rear of the car), push them up above the bracket mount and screw them back in. Gives you about 4-6"s of clearance. Not as much up front by the cat, but more than what you have now.
