what bolts and gaskets are needed?
7 Second Club
doing a cam swap what gaskets and bolts will need to be purchased for cam and spring swap?
just trying to get everything rounded up that ill need.
Tyler
Tyler
You can get a cam swap gasket kit from TSP. It has everything you need.
Crank bolt
Water pump gaskets
front main seal
timing cover gasket
Read http://ls1howto.com/index.php?article=23 if you haven't yet.
It will tell you everything you will need for a cam swap, from tools to gaskets.
Crank bolt
Water pump gaskets
front main seal
timing cover gasket
