need instructions for prothane
i just bought a set of prothane motor mounts. Unfortunately the directions where cut off (bad photocopy i guess) can anyone scan them for me? or perhaps write them down?
thanks
jimmy
thanks
jimmy
thanks
jimmy
thanks
jimmy
what about the parts on the prothane piece that you have to drill? and what side is up, and what side is down (the side with 2 nubs, or with 4 nubs)
thanks
jimmy
thanks
jimmy
thanks
jimmy
thanks
jimmy
you can put them in two ways actually, with the tabs on the metal at the top or bottom .....
drill the rivets out on the clamshell and then drill the holes on the other end with a 3/8 or slightly larger bit
im working on some for a friend right now and they are a pita to install and this is my 2nd set installing
drivers side is the beeyyaaach
where did you get your mounts? The only sponsor I've found that lists them is Thunder and I had a bad experience with them before and promised myself not to buy anything from them.
Sorry to hear you had a bad experiance with thunder because they have been awesome to me for the last 5 years. But, you can order them from Summit for $39.99.
Also, according to my directions, the bolts go away from the car (insert bolts from bottom side of clamshell). I know there is a thread about this already. I would do a search because there is more info out there..
Dan
Dan
