What Is The Easiest Way To Remove The P/s Pump?
Old 03-22-2005, 10:17 AM
SICKBIRD's Avatar
Default What Is The Easiest Way To Remove The P/s Pump?
Mine In Starting To Go Out.
Old 03-22-2005, 12:33 PM
technical's Avatar
Get a PS pulley installer/remover tool from the local automotive store. (Pep Boys, Napa, Autozone, etc.)
Pull the pulley. Carefully loosen the lines. Unbolt the pump.
Viola!!!
Old 03-23-2005, 06:08 PM
WILWAXU's Avatar
If you don't want to remove the pulley, you can use a gear wrench to remove the mounting bolts.
Check out the cam install on www.ls1howto.com to see what I'm talking about,
Old 03-24-2005, 09:54 AM
technical's Avatar
Does a new pump come with a pulley?
Old 03-24-2005, 12:46 PM
Flielow's Avatar
No. When you have to replace your p/s pump and order it from a parts shop it comes bare, no pulley, no reservoir, and no p/s hoses.
Are you removing it because it leaks?
Make sure you check the reservoir and lines for leaks, when I changed mine I found out that my reservoir ($40) had a crack in it and that was much cheaper than replacing the pump.
And for removing the p/s pump you can unbolt the bracket that it's resting on. The only hard bolt is the one that is directly behind it, theres not too much space
Hope it helps
