LS2 Intake Manifold
LS2 Intake Manifold
It is a direct bolt in but, you have to use a 90mm TB with the LS2 intake. Unless you have a radical engine or a large cubic inch engine, the LS6 will give the best performance results. I would go with the FAST over the LS2 if those are the choices, but in your case I think the LS6 would be your best choice.
