service vehical light
Old 03-24-2005, 09:45 PM
chris77's Avatar
Default service vehical light
can anyone tell me how to reset the service vehical light, and why it comes on. i have a 2000 TA, and the light comes on at least twice a day. i have already reset the oil change, and there are no trouble codes, so what do i do know. please help.
Old 03-24-2005, 09:54 PM
LS1s R US's Avatar
Ya will have to reset the light by disconnecting your battery! But I would get it checked by a scan tool to see what the problem is! those pesky ses lights worry the crap out of me to!
Old 03-24-2005, 09:58 PM
TNC_LS1's Avatar
If You Dont Have A Scan Tool Go To Autozone...its Free
chris77's Avatar
this is not a sevice engine soon light, its the service vehical light. i do have a scan tool, and like i said there are know codes. my ses light has never gone off
Old 03-24-2005, 09:59 PM
ddelallata's Avatar
turn the ket to the ON position then disconnect the PCM batt and PCM Ign fuses under the hood. they are in two different fuse boxes on the driver's side. Leave them off for a few minutes then put them back on and turn the key to the OFF position. Then turn the car back on and it should have turned off.
Old 03-24-2005, 10:58 PM
chris77's Avatar
o.k. i will try it, but i would still like to know why it comes on. can some give me an answer.
Old 03-24-2005, 11:04 PM
Speed2k2z28's Avatar
do you have any aftermarket tuning? if so change any "c" codes to "x" and see if that changes it. if not sevice vehicle usually refers to a non-emission fault ie headlight out, problem with door locks,etc
what is done to your car?
Brian
Old 03-24-2005, 11:13 PM
chris77's Avatar
the car has a tr224 cam,comp 918 springs, comp push rods, ported tb, ported maf, smooth elbo, air lid, slp lt's, carsound cats, flowmaster catback, ls6 intake, and ported oil pump. the car was tuned, and made 384 rwhp. the front head light did go out last week, but i fixed it.
Old 03-25-2005, 06:14 PM
normally it goes out immediately after the problem is fixed. service vehicle codes don't come up on a scanner did this just start when the headlight went out,or has this been an issue for a while?
Brian
