TSP True Duals w/ eibach sportlines pics
Old 03-27-2005, 06:53 AM
jj_z28's Avatar
Default TSP True Duals w/ eibach sportlines pics
Here ya go, tell me what ya think. I know it is going to scrape BAD! On a side note I'm turning the bullets 45 degrees and raising them as much as possible. I want them out the back under the axle SOON! And if anyone wants to know, I have Pacesetter Long tubes w/ a BMR torque Arm. I also am reworking my Lakewood DSL to work w/ this setup.
What do you think :
1: Leave them and see what happens
2: go back to stock springs
Attached Thumbnails TSP True Duals w/ eibach sportlines pics-480x360_img0146.jpg   TSP True Duals w/ eibach sportlines pics-480x360_img0147.jpg   TSP True Duals w/ eibach sportlines pics-480x360_img0148.jpg   TSP True Duals w/ eibach sportlines pics-480x360_img0153.jpg
Old 03-27-2005, 08:18 AM
Turo's Avatar
Do yo go over speed bumps or bumpy roads? That setup wpuld not work for me, the speed bumps in my apt complex are like Mount Everest, but if it works for you then keep them. I say leave it for now and see what happens, drive carefully for the first few days and see if you scrape anywhere. If not, then keep it. If you do, then swap the springs.
Old 03-27-2005, 08:22 AM
Nate_Taufer's Avatar
which bmr tq arm do you have? I got the duals and have about 3.5" of clearance where the tips dump and a little more all around. I haven't scraped yet and hope not to.
Nate
Old 03-27-2005, 08:56 AM
Hardtop00SS's Avatar
sportlines & TD's!? clearance looks scary, car looks bad *** though!
Old 03-27-2005, 09:04 AM
jj_z28's Avatar
Thanks Hardtop00ss
Yea, hangs rather low and I knew it would.
taufern, I am running the adjustable torque arm that mounts in factory location.
And no, I fear no speed bumps Well, maybe, I haven't even had a chance to drive it yet.
Old 03-27-2005, 09:31 AM
ddelallata's Avatar
you are a brave man my friend.
Old 03-27-2005, 09:46 AM
2_wacko's Avatar
Thats close but nice.
Old 03-27-2005, 08:48 PM
fasthwks's Avatar
I had that same setup on mine and loved the sound but even driving it around town I would scrape with the littlest dip in the road, I lasted about two weeks! It was hard to get rid of tds but the drivability was worth it. The bad thing is I only drive mine 7k a year and I could not get in and out of my garage without dragging the bullets. My clearence problems were not with the x it was with the bullets. Good luck!
Old 03-27-2005, 09:16 PM
01RedZ28's Avatar
I have prokit springs and the speed inc true dual and i scape everything i acturally broke off one of my clamps coming out of the driveway today. But i like them to much to go back with a catback.
Old 03-27-2005, 09:17 PM
ProjecT 9's Avatar
haha...wow, i bet you could peel a bananna if you drove over one!
Old 03-27-2005, 09:26 PM
LS1Adam's Avatar
that is the exact setup I will be running in about a month or two! I've got pacesetter LTs and sportlines right now and will be getting TSP TD's for my b-day from the g/f. NIIICE CAR and SETUP BTW!!!
When I had my exhaust unhooked i had the same ground clearance you have now and going over speed bumps I would scrape. After that I never drove over another speed bump even if it meant walking an extra mile. Driveways and inclines I was extra careful.
I was also thinking of the BMR Trak Pak but wasn't sure about clearance issues with it and the duals. Maybe i'll just do the adj TQA instaed.
Old 03-27-2005, 09:29 PM
LS1Adam's Avatar
How is clearance with the TQA and duals? have any pics of the clearance?
Old 03-27-2005, 09:32 PM
brewerz28's Avatar
yeah everyone told me that it would suck to drive but i was going to stick it out. i had 3"tsp trueduals and hooker longtubes and prokit. it wasnt that bad. but i decided to make it straight race car so i put stock ss springs back on. i think you wont mind it that much.
Old 03-27-2005, 10:43 PM
UGotBeaT's Avatar
looks good i have the same setup sportlines three inch tsp duals and pacesetters and it scrapes every once in a while just gotta know how drive
what i hate the most is when theres like two people in your car other then you that weight at least two hudnred pounds then u just start scrapin everywhere so learn from me dont let more then one person in your car!
Old 03-27-2005, 11:21 PM
Camaro99SS's Avatar
I can't tell, but if you haven't already, flip the clamps sideways. That will make the mufflers the lowest part instead of the clamps. A few decent scrapes, and you'll ruin the clamps in no time.
Jason
Old 03-28-2005, 12:01 AM
ZR2877's Avatar
Keep them see what happens. I have TD's and lowered 1.5" and I don't scrape much. I ran mine out the back. I have 3" off the headers and a 3" X and mufflers then I have 3" cutouts then 2.5" ran out the back. I like the sound of dumping under the car but I run it out the back most of the time.
Old 03-28-2005, 12:17 AM
LSONE's Avatar
how tight is that DS loop with those duals? i'm looking to pick a DS loop up and need to find one that will fit
Old 03-28-2005, 12:57 AM
DocEwww's Avatar
Youre CRAZY. Im near stock ride height (adj coilovers) and my dumps even scrape.
Old 03-28-2005, 01:00 AM
35thls1ss19's Avatar
Wow looks very good, but a little to close for comfort Good luck though
Old 03-28-2005, 04:35 AM
jj_z28's Avatar
LSONE : I had a Lakewood DSL, but I knew this wouldn't work w/ the way my car is setup, because you lose lots of clearance w/ the TSP true duals and a chassis mounted DSL, but I am going to try and modify the way it mounts and hopefully get away w/ keeping the DSL I have.
If anyone cares, I hopefully will be getting some footage of the car and the exhaust Monday and will be posting as soon as possible. But I guess u heard one car w/ this setup, you heard them all. O WELL
Quick Reply: TSP True Duals w/ eibach sportlines pics
