Magnaflow duals
Old 03-29-2005, 09:16 PM
JerikSS's Avatar
Default Magnaflow duals
Has anyone tried the magnaflow dual in/dual out muffler on true duals? Is it loud? I just finished a cam install and my dynomax are to loud. I just dont want to loose alot of hp/tq. I am thinking installing the dynomax before the axle and the magnaflow where the stock exhaust is. About how much will I loose? How quiet is it going to be?
Old 03-29-2005, 10:07 PM
JerikSS's Avatar
need feedback, cops in Ca are not that great
Old 03-30-2005, 12:10 AM
kpowr82's Avatar
If hooker makes a dual in/dual out Aerochamber, you won't be dissapointed. It sould quiet it down quite a bit. And Hookers flow great.
Old 03-30-2005, 01:11 PM
JerikSS's Avatar
so about how much power will I loose with both the dynomax and the magnaflow muffler together
Old 03-30-2005, 01:13 PM
GuitsBoy's Avatar
Should be imperceptible. Both are flow through designs. The only restriction is the drag of the perforated holes in the inner muffler tube.
Old 03-30-2005, 01:32 PM
dug
dug's Avatar
I dont understand the setup youre proposing.
I bought a dual i/o 4x9" magnaflow muffer with built in xpipe. I have macs and going to install the muffler before the ycollector and dump it under the car.
