which first
Old 04-03-2005, 01:17 PM
seppe855's Avatar
Default which first
am saving up $$$ for either a cam or headers which should i get first
Old 04-03-2005, 01:26 PM
snake charmer's Avatar
Headers for sure. A cam loves to breathe air in and out. Then once the car is breathing right for sure a cam. On stock manifolds even a good cam will not see much in gains.
Old 04-03-2005, 01:32 PM
seppe855's Avatar
qtp or kooks right i heard they are good
Old 04-03-2005, 01:35 PM
f-bodman's Avatar
Definately headers first, you can't go wrong with either QTP's of Kooks.
Old 04-03-2005, 01:57 PM
seppe855's Avatar
what do i exactly need if i get kooks or qtps.like 1 3/4 or 1 7/8, y pipe, extensions
Old 04-03-2005, 02:30 PM
BryanSS's Avatar
Get 1 3/4.......you don't need 1 7/8......Y pipe is personal choice weather you want a catted or ORY... A cam that can't breath is not going to get you the numbers you are looking for at all.
Old 04-03-2005, 03:33 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Headers---Mine are finally on the way....
Old 04-03-2005, 04:35 PM
Josh's Avatar
Another vote for headers. If you run an aftermarket cam with the stock manifolds, the gains will be very similar to the gains you would get from a good set of headers.
Josh
