Searched... Underdrive pullies. Anyone with proven gains?
Old 04-07-2005, 09:59 PM
BrandonSS's Avatar
Default Searched... Underdrive pullies. Anyone with proven gains?
I searched but didnt come up with a concrete answer. I've seen a few sets of underdrive pullies on some of the sponsors sites. They claim 10hp.
Now, 10hp at the wheels is a good bang for the buck mod for something in the neighborhood of $200. Esp if you add it to a ported TB that usually sees 7hp gains for $75. That would nearly be 2 tenths off the 1320 time right?
I just want to see some concrete evidence or first hand experience with these mods.
TIA
Brandon
Old 04-07-2005, 10:14 PM
BLASTER's Avatar
Yes, I have proof. Search for ASP with my name and you should see my graph.
I gained in all 3 areas - HP, ET, and MPH
I saw 10 hp gain throught the RPM range; shaved a 10th off my 1320 time and gained a MPH so it's definately proven and worthwhile to do.
Old 04-07-2005, 10:25 PM
BrandonSS's Avatar
Good info. Is there any negative effects on the car? Idle voltage, power steering harder, etc.
Thanks again
Brandon
Old 04-07-2005, 10:27 PM
BLASTER's Avatar
Thanks again
Brandon
Nope. I had a plug in cigarette lighter and saw no adverse effects afterwards. Voltage is still 13.2
Old 04-07-2005, 10:36 PM
setxws6's Avatar
I don't have any dyno results for you. But unlike a catback or lid, you will notice this mod the moment you drive down the road. I sure did. It's worth it so just DO IT!
Old 04-07-2005, 10:45 PM
SmaknaSS's Avatar
I love my ASP. three years now, still works great.
Old 04-07-2005, 10:47 PM
BrandonSS's Avatar
OK now these 10hp gains... are these attained with just the crank pulley or should I invest in all available pullies? I know alt is available but cant remember if any others are.
Thanks!
Old 04-07-2005, 10:59 PM
SmaknaSS's Avatar
Thanks!
First of all I could be wrong but I think if you put the all the after market pulleys on, the UD pulley itself will be less effective. I think they made the other pulleys for people who might have had problems with their alternator not charging or not enough steering assist.
Old 04-07-2005, 11:01 PM
setxws6's Avatar
Dude, your an M6, no idle problems with alt. Get the crank pulley and have fun.
Old 04-07-2005, 11:03 PM
LS1ownzYOU's Avatar
Search button.......
Gotta look harder, theres plenty of info out there. I had issues with charging that I fixed by charging the battery over night. Plenty of info out there.
Old 04-07-2005, 11:20 PM
BLASTER's Avatar
Just the lower.....
360hp/376ft.lbs (BLUE) with all the bolts ons versus 351hp/365ft.lbs (RED) without the pulley. I'm happy that the ASP was good for 9-10hp since it was my last bolt-on.
Old 04-07-2005, 11:50 PM
2kpewterws6's Avatar
so all that is really necessary is to buy the one crank pulley?
Old 04-08-2005, 12:03 AM
BLASTER's Avatar
yep. add new crank bolt, and two new belts. plus if you will be installing it you will need a puller and a longer bolt/installer rod
Old 04-08-2005, 01:57 AM
Stone0fFire's Avatar
i read that contrary to internet belief,
the crank bolt is not a torque-to-yield bolt,
so you can reuse it
but you have to use loc tite on the tip and near the base of the bolt.
anyone near los angeles that can help me install mine?
ive had it for almost a fricken year.
asp crank and alternator
Old 04-08-2005, 02:08 AM
Another_User's Avatar
so you can reuse it
Even if it is not a torque to yield bolt, you are much better off replacing it. It is one of those bolts you really don't want to take chances with...kind of like head bolts. It is one of those good mods that will actually let you recover some low-end power that is lost from other mods, and it is nice that all the power is not just in the top rpms where your car does not normally (well...some cars) see on the street. I have never seen any negative effects. On a tuned cammed car I would not worry about it at all. If you bump your rpms up even 100 rpms to compensate for the cam, then you are already increasing how fast you are spinning all your accessories at idle 12+%, and that is half what you lost for spinning your alternate, etc anyways. It is definitely a worthwhile mod.
Old 04-08-2005, 08:46 AM
LS1ownzYOU's Avatar
so you can reuse it
SDPC, get in contact with K. Jones the bolt is like freaking 7 dollars shipped. You can ethier spend the 7 bucks for a new bolt, or 4 grand for a new moter when your pulley spins off at 80 mph on the highway. Up to you
Old 04-09-2005, 03:04 PM
SmaknaSS's Avatar
Damn! my car didnt come with a (moter).
Old 04-09-2005, 05:18 PM
God Forgives I Dont's Avatar
