Fast 90 with 224 cam... too much?
Old 04-08-2005, 11:18 AM
zupmanZ28's Avatar
Default Fast 90 with 224 cam... too much?
I'm looking at getting a Fast intake, and i'm wondering if the fast 90 would be a step in the right direction or overkill.
My setup is: stock 346 bottom end, TR 224 cam (114lsa), TEA 5.3 stg. 1.5 heads, an ls6 intake, ported tb, MAC mid lengths w/ory, PT4000, stock 4l60e, 3.73's.
I'm still new to this efi stuff, i'm used to carbs. I know it's very easy to over carb a motor, so i imagine it would be just as easy to over TB it as well.
A few more questions;
will the fast 90 intake work with a smaller tb? (i assume not, since there would be no point in having two manifolds if they did).
Will my stock injectors/pump be able to keep up with a 90mm tb?
I'm sure this has all been covered before, but i tried searching and didn't come up with much, thanks for the help.
Eric
Old 04-08-2005, 11:23 AM
Tranzor's Avatar
I don't think it would be overkill at all... heads/cam packages find a pretty decent benefit from a 90/90 setup once the tune is tweaked to account for it. If you have the money to spend, go ahead and get it.
Old 04-08-2005, 11:44 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
You can't "over TB" a fuel injected vehicle....Its not relying on carb signal and airspeed to meter and correctly atomize fuel....that task is handled much more efficiently by your fuel injectors. The TB is simply an "air valve" and it will only allow whatever the engine is capable of drawing thru it. Too small a TB can hurt you, but there is almost no such thing as too big. The FAST 90 even on a mild H/C car is worth a solid 15 RWHP all else being equal. As someone else said, if you have the money, go for it....it offers a sizable power gain without hurting low speed torque production (like installing a larger cam to see the same "peak" gains the FAST 90 set-up will provide).
Every dyno test I have personally been involved in has liked the FAST set-up....even a bone stock LS1 gained 10-12 HP with no other changes (and that was a 78 mm test).
Go for it....
Tony M.
Old 04-08-2005, 12:09 PM
zupmanZ28's Avatar
thank you folks, you have been quite helpful.
I've got lots to learn about this efi stuff....
Eric
Old 04-08-2005, 01:46 PM
BBQLS1's Avatar
Go for it....
Tony M.
Even over the LS6 intake LS1's?
Old 04-08-2005, 03:44 PM
Wicked_Hugger99's Avatar
wondering that myself
and what would the gain be going from LS6 intake ported stock TB to a LSX 90/90 setup on a bolt-on car w/ an F14 cam and 100shot nx wet?
Old 04-08-2005, 06:14 PM
BoneSS's Avatar
That is what I would like to know:
Mild h/c
LS6/Ported TB
vs
90/90 setup
Old 04-08-2005, 09:17 PM
zupmanZ28's Avatar
Mild h/c
LS6/Ported TB
vs
90/90 setup
i would love to see this comparison as well. I've searched through the dyno forum, and have found several comparisons on 230+ plus cam packages, but nothing on "mild" cam cars.
Eric
Old 04-08-2005, 11:12 PM
86 IROC's Avatar
JS on here has a mild 224 cam w/ heads and a 90/90 set up. You might want to check his car out, runs strong for a "mild" set up.
Old 04-08-2005, 11:31 PM
pdd
pdd's Avatar
go for it
Old 04-09-2005, 12:09 AM
98darkbird's Avatar
If you wanted to see a real boost...I would suggest a larger cam to complement the FAST intake.....maybe some thing around 230/230 .598/.598 112 lsa....still would be streetable....but would move the rev's farther up...and use that larger intake. ENJOY!
Old 04-09-2005, 04:35 AM
smokin' joe 00 ss's Avatar
Ok I run a small cam B1 221/221- >559/.559 and stage 2 heads and I gained 27rwhp & 13rwtq over my LS6 intake and ported TB with my 90mm FAST intake & TPIS 90mm TB. Both Dyno's were done on the same Mustang Dyno.
Old 04-09-2005, 05:22 AM
zupmanZ28's Avatar
I drive this car no less than 80 miles a day, and i love mildness of my 224 cam. i'm sure it would still be streetable with a 230/230, but i see no point in changing something i'm happy with. Right now i see the intake as my bottleneck. On top of all that, TEA told me to stay below at or below a 228/228 cam with these heads.
Eric
Old 04-09-2005, 05:41 AM
BoneSS's Avatar
I think me and you are in the same boat. TEA told me to expect 15 over the stock setup.
