true duals
Old 04-09-2005, 07:52 PM
forurwife's Avatar
Default true duals
Need to know if texas speed true dual set up will bolt up the hooker long tubes or do i need other parts
Old 04-09-2005, 07:58 PM
DOUBT IT's Avatar
Yep, bolt right up. ( I have Pacesetters, but I've heard everyone say they bolt right up )
Get 'em, they rawk!
Old 04-09-2005, 08:26 PM
forurwife's Avatar
thanks hey when u got it on did it take alot of the rasp out...and was it louder..right now i have hookers and flowmaster american thunder
Old 04-09-2005, 08:39 PM
DOUBT IT's Avatar
I have ZERO rasp. I might be going deaf though.
One thing you don't want to forget is to flip your fuel lines. See this thread here for my explanation on that.
https://ls1tech.com/forums/generation-iii-external-engine/301110-any-else-remove-rear-heat-shields.html
Other than that, the only advice I can give is to get a sharp razor knife to cut an access hole to install the bolts, and also make sure that you have good clearance everywhere before you mount them. I had to remount mine once 'cause the ground clearance wasn't great. Just take you're time and you'll do fine!
Old 04-10-2005, 12:01 AM
Crazy Man's Avatar
yeah its a direct bolt on my buddy has hookers and the exhaust bolted right up same with my pacesetters..
Old 04-30-2005, 02:10 PM
forurwife's Avatar
doing the install today and need to know what the two hangers bolt up to in the back. have hooker long tubes and the hangers are about 5 inches to long
Old 04-30-2005, 02:30 PM
forurwife's Avatar
also i have read that people are not having any problems with hitting the ground but it doesnt look like that will be the same for me please help
Old 04-30-2005, 02:45 PM
jamnut's Avatar
Here is a little clip with mine. www.kornbread-racin.com/camidle1.wmv Right click & save as please.
They look low in the clip, but they were just mocked up after my H/C install. They do ride a little low, but my car is lowered. On the 26" ET Streets they ride a lot higher than when I'm running the 315-35-17's. They are a little loud these days with the H/C & stuff, I love the sound, but my neighbors hate me.
Old 04-30-2005, 02:49 PM
forurwife's Avatar
so do the scrape the ground and did u have any problems with the last two hangers being to far back
Old 04-30-2005, 03:01 PM
jamnut's Avatar
They don't scrape the ground. The damage you might be able to see on them is due to the fact that I hit an 18 wheeler drum brake in the center of the highway @ about 75 mph & it pulled the hangers out of where I had them mounted. So they hit the highway. Just make sure that you have your rearend supported when hanging them so you can get all the clearance you can under your torque arm.
Old 04-30-2005, 03:20 PM
forurwife's Avatar
got true duals on but now the pipes lay on the ground when it is off of the lift any ideals would be great thanks for the help...
Old 05-01-2005, 07:48 AM
jamnut's Avatar
Did you install them on a lift that lift's the car by the frame or the wheels. You need to make sure that the rear suspension is loaded so the torque arm is up out of the way if you don't have the wheels supported, you won't be able to get the duals up high enough to get ground clearance. That's why muffler shop's use lift's that you drive the car on instead of the ones with the little arms that lift the car by the frame.
