can the maf and tb be combined together?
Old 04-14-2005, 07:02 PM
jimmyp's Avatar
Default can the maf and tb be combined together?
ive got some clearance issues and I was just wondering if it would be ok to cut them both down and weld them together?
Is there some sort of rule as to how far the maf must be from the tb?
thanks
Old 04-14-2005, 07:11 PM
soundengineer's Avatar
I have been thinking of a custom intake...and it would require me to put my MAF and TB together...not going to cut and weld...but I am going to butt them up together nice and tight.... now I just have to figure out a freakin filter that fits the way I want it to.....
Old 04-14-2005, 07:21 PM
cyphur's Avatar
just ditch the MAF and run a speed density tune.
Old 04-14-2005, 07:23 PM
jimmyp's Avatar
speed density tune? hmm explain more
Old 04-14-2005, 07:42 PM
WS6FirebirdTA00's Avatar
u tune your car with the maf off and leave it off. it just runs off of your ve table and low octane tables, i dont know what the other differences are but maybe otehrs can explain.
i have my maf gone right now, tuned it out with hp tuners, car runs GREAT. response is incredible. car runs very smooth as well. maf sensor is not a necessity. my friends s10 doesnt have one and it just runs richer in the summer. which isnt so bad really. only about an 8% difference in airflow.
Old 04-15-2005, 02:53 AM
Lvmyz28's Avatar
Don't mess with speed density unless you have some serious tuning expertease! A lot of hot rodders run the MAF right in front of the TB. You can put it anywhere you want as long as it is before the TB!
Old 04-15-2005, 08:51 AM
RedHardSupra's Avatar
i've been thinking of putting my maf right in front of TB, instead of lid->maf->bellows->TB, because i hate the angle at which the stupid fernco bellows sits. any suggestions if it's a good thing? i'm afraid that MAF readings might get goofy if TB closes suddenly and MAF gets a pushback of air that gets blocked, throwing off readings.
Old 04-15-2005, 09:39 AM
jimmyp's Avatar
yea id like to confirm if it can be stock right against the tb also...if not ill just place it about 18" up the intake tube right before the filter.
Old 04-16-2005, 08:42 PM
jimmyp's Avatar
somebody has got to know the tech specs of the MAF location...
Old 04-16-2005, 10:12 PM
maf is fine against the TB, grand prix come like that, tb and maf in one
Old 04-16-2005, 11:39 PM
cyphur's Avatar
if you don't want to go SD, then putting them right up against eachother will be fine.
