tunnel brace
Old 04-19-2005, 11:27 AM
Coy
Coy's Avatar
Default tunnel brace
I was able to reinstall the tunnel brace on my car after I installed hooker longtubes, but the Intermediate exhaust pipe sits right on it and makes alot of vibration. Is ther any other way to mount it(with spacers) or should I just ditch it completely? Could I use some king of material beetween it and the pipe to get rid of the Vibration? Thanks.
Coy
Coy's Avatar
BTW, I have no banging issues.
Old 04-19-2005, 11:30 AM
technical's Avatar
Bend it.
Old 04-19-2005, 01:01 PM
snketr's Avatar
I put 3 washers on each bolt. Worked perfectly
Old 04-19-2005, 08:24 PM
M6HuggerSS's Avatar
i just took it off.... its to thin to do anything anyway...
Old 04-19-2005, 08:43 PM
LS1Maniac's Avatar
It's really not worth the effort. It doesn't do hardly anything as far as tightening up the suspension. My suggestion is to ditch it and if you're concerned about rigidity then get a set of subframe connectors. I haven't had my tunnel brace on since I went true duals last spring.
Old 04-19-2005, 10:35 PM
Coy
Coy's Avatar
Ditched it, got rid of the problem. I'm getting some kb dd's
Old 04-19-2005, 11:11 PM
LS1Maniac's Avatar
Good to hear.
Old 04-20-2005, 07:21 AM
Blacker's Avatar
I threw mine away.
