160 Thermostat
Old 04-19-2005, 12:37 PM
Buceman's Avatar
Default 160 Thermostat
Has anyone installed one? Do you get soaked? Any tricks etc.......
Please help with install.
Thanks Buce
Old 04-19-2005, 12:40 PM
BADSZ28's Avatar
So easy. I let my little brother do it. You will be draining some fluid. No biggie, just get some more and top off the radiator, and overflow tank and whatch the level after it warms up (in the bottle, not the radiator. Then you would get soaked).
Old 04-19-2005, 12:42 PM
BADSZ28's Avatar
Oh...remove the hose first, then the thermostat, reinstall 160 and replace hose, top off fluid and you are done. Easy.
Old 04-19-2005, 12:48 PM
shouldaboughttheZ's Avatar
Thanks Buce
Would be a good time to do a coolant flush.
Old 04-19-2005, 12:59 PM
2001NBMZ28's Avatar
www.installuniversity.com has a tstat swap writeup w/pics
Old 04-19-2005, 01:02 PM
Buceman's Avatar
Thanks guys!!
I thought it would be easy but I just didn't want to make a complete mess and *** of myself.
Thanks again Buce
Old 04-19-2005, 01:15 PM
BADSZ28's Avatar
You will lose about a gallon, but it should just go straight down. Be sure to have a drain pan under the car. Good luck and have fun!
