Funny noise from exhaust after spark plug change (sound clip)
Old 04-20-2005, 01:16 AM
calys968's Avatar
Default Funny noise from exhaust after spark plug change (sound clip)
I changed my spark plugs last weekend and now there is a popping noise coming from my exhaust. Right after the change I got a trouble code for a misfire on Cylinder #1 but after pulling that plug out and putting it back in the code stopped. The #1 spark plug didn't want to go in all the way, I even had my boyfriend try and he said it feels like it might be cross threaded.
Somebody told me the popping noise means it's misfiring but if it was misfiring wouldn't I still be getting that code?
Here's a sound clip... http://www.blackout-studios.com/exhaust1.mp3
Old 04-20-2005, 07:59 AM
shouldaboughttheZ's Avatar
Did you get the #1 plug back in fully?
It might be misfiring. Even though it is misfiring there might not be a code showing. As in my case. Mine is misfiring due to the crank position sensor. I get no codes.
Old 04-20-2005, 08:20 AM
calys968's Avatar
We weren't able to get the #1 spark plug in all of the way. I was planning on taking it to the shop today and having my mechanic look at it but I thought I'd ask about it here first.
If it was misfiring would performance be affected?
Thanks for your help.
Old 04-20-2005, 09:58 AM
Yes it would. As mine does on take off and idle.
The sound on the clip (popping noise) might be the plug not fully in and the compression blowing by the plug.
Old 04-20-2005, 10:33 AM
98Z-6Speed's Avatar
Does the plug ever get tightened down firmly?
Quick Reply: Funny noise from exhaust after spark plug change (sound clip)
