Need to be quieter...
I have true duals with the mods in sig. 3" Sweet Thunders dumped at the axle is quite loud while at idle/cruising/WOT. They drone on the highway but offer good clearance. I am looking for good clearance and less drone around 2-3k. Did some searching, looking for info from anyone who has experienced anything that would fit my needs. Saw the Pro-Flows and Spiral Flows are usually a quieter option. I miss the sound of my Flowmasters, but don't miss the clearance issues...
I don't have any experience with these, but you may consider trying a set of those silencer cones from Dynatech. I know Jegs sells them, and I'm sure Summit does too. I'd do that before switching mufflers, but if you insist, the Flo Pro Twisters would be your best bet.
Jason
Jason
Originally Posted by jimmyblue
I think you want the exhaust exit out from under the
floor pan.
floor pan.
A bit too much 'redneck cheap I can't afford a real exhaust' experiement to me, but you have to see it to believe it, words just don't cut it.
