best plugs?
Old 04-23-2005, 03:01 AM
JRSSTOY's Avatar
Default best plugs?
Im trying to get some advice from all you guys Im about to replace my spark plugs on my 98 SS and I dont know if should stick to the stock ACDelco or if theres any thing better out there?
Old 04-23-2005, 08:47 AM
crizain's Avatar
NGK TR55's I have always run these, a bit more expensive but no reason to skimp on basic maintenance items.
Rob
Old 04-23-2005, 09:03 AM
SStheBest's Avatar
either NGK TR55's or the ones im gonna use in a few weeks are the AC Delco iridium plugs....BEST FOR THE LS1's....damn $7+ bucks a plug though
Old 04-23-2005, 09:08 AM
WAHUSKER's Avatar
I run TR55s, and plan to try a set of TR6s to see if the cooler temp helps any. I've seen charts showing the Denso Iridiums are "the best plug" becuase the have the lowest misfire rate of any plug on the market. (so you get less knock) But I tried a set when I was having some KR issues, acutally 2 - they came stock in my car, and still had knock. So at 1/4 the price, I now run the NGKs.....
Old 04-23-2005, 10:51 AM
JRSSTOY's Avatar
Do you know how much these NGK plugs are because I know the ACDelco are about & dollars a piece?
Old 04-23-2005, 10:56 AM
ddelallata's Avatar
NGK tr55 are about 2 dlls a piece or less at Advance Auto Parts.
Old 04-24-2005, 12:32 AM
Red99TransAm's Avatar
I put in the Bosch platinum +4 and they have been working great so far. Cost me $56, if I remember correctly? But so far I have no complaints.
Old 04-24-2005, 03:18 AM
SStheBest's Avatar
those are the worst plugs u can buy for a car....MUCH LESS AN LS1!!! ...id get those outta there ASAP!!!
Old 04-24-2005, 03:19 AM
SStheBest's Avatar
ask anyone about bosch plugs and their gonna say the same thing.....i think there is a search on this.....
Old 04-24-2005, 03:56 AM
RedHatRdRacer's Avatar
TR55 for motor, TR6 for 150+Nitrous
here there 1.49 per plug
Old 04-24-2005, 03:59 AM
Schantin's Avatar
I installed NGK TR55 plugs about 200 miles ago and have been happy with the performance so far. I'd stay away from the platinum plugs and replace the origonal platinums with either standard plugs (aka the TR55's) or an iridium plug. The platinum doesn't seem to hold up well under WOT conditions.
If changing spark plugs is a fate worse than death for you, get the iridium. I had these on my 97 LT1 and was happy with them. If you don't mind changing plugs every 30K miles, the best bet is the "normal" NGK TR55's. A spark plug change can be accomplished with the right tools in about an hour on a LS1. This is my suggestion
BTW, the NGK TR55's are WAY CHEAPER than the AC Delco factory Platinum plugs. I got all 8 plugs for under $20.
Schantin
2002 Camaro Z28 M6
Old 04-24-2005, 08:42 AM
ace68's Avatar
there is a new plug out there that was dyno tested against the tr's and mad 3 rwhp.
Old 04-24-2005, 09:23 PM
01_SuperSlow's Avatar
Denso Iridiums do not come stock on LS1's.
The stock plugs are some other type of Denso plug, I believe they are some type of platinum plugs.
I know this because my SS and 5.3 Silverado came with some Denso plugs, and when I compared them to the new iridium plugs, they had a different tip and the stock ones do not say "iridium" around the plug either.
Old 04-25-2005, 09:34 AM
VTC_WS6's Avatar
What gap do you guys run on your TR55's? I installed a set during my LT install Sat. but I didn't have any gap info for the LS1 on hand so I had to 'guess'. I ended up running a .035-.037 gap, I hope i'm somewhere in the neighborhood!
Old 04-26-2005, 08:31 PM
Coy
Coy's Avatar
wow that is damn far off. Between .050-.060.
Old 04-26-2005, 08:32 PM
White.Lightning's Avatar
AC Delco plugs and oil filter. Always have always will.
Andy
Old 04-27-2005, 05:10 AM
ZodiacZ28's Avatar
I ran tr55's and found that on my header swap that one of my plugs was fouled out. Im going to change over to ac delco and see how it goes.
Old 04-28-2005, 12:04 PM
Phoenix 5.7's Avatar
should i get the TR55 regular or the iridium ones?
Old 05-01-2005, 01:07 AM
hogs's Avatar
Default Aussie Spark Plugs?
G'Day,
First post fellas so be kind to a boy from OZ!
NGK TR55's seem to get a good report, but I am not sure if they have an equivilent here. A lot of the 1/4 mile boys use NGK BPR6EF??
Anyone know if this is a similar plug?
Cheers,
Hogs,
"GO HARD OR GO HOME"
Old 05-01-2005, 11:08 AM
FedZ's Avatar
Definately the NGK TR55 for the money. Go with iridiums if you have the extra $$
Quick Reply: best plugs?
