How Do You TroubleShoot Starter and Solenoid?
Old 04-26-2005, 11:30 AM
dug
dug's Avatar
Default How Do You TroubleShoot Starter and Solenoid?
My car wont start but I get a click when I turn the key. I can pushstart the car no problem.
I checked the battery and grounding and theyre both good. I am thinking maybe its the solenoid. How do I check if its the solenoid and not the starter?
tia
Old 04-26-2005, 11:33 AM
99blancoSS's Avatar
Are you sure the battery is ok? Used to be you could cross the terminals on the starter with a screw driver to check it but that was on my 72 chevelle w/350. I would just take it out and take it to a shop and have it checked. Its 2 bolts and like 3 wires w/nuts.. takes 5 minutes to remove and install.
Old 04-26-2005, 11:36 AM
dug
dug's Avatar
Yeah, the battery is supposed to be ok. I took it to AutoZone and they checked it.
99blancoSS's Avatar
I would just take it out (starter) and take it to a shop and have it checked. Its 2 bolts and like 3 wires w/nuts.. takes 5 minutes to remove and install.
Old 04-26-2005, 12:58 PM
dug
dug's Avatar
Sounds simple enough. I will just take it off and check it.
Old 04-26-2005, 05:51 PM
30th droptop's Avatar
You actually can jump the terminals on these starters, although I wouldn't do it with a screwdriver. I've done it with a remote starter switch.
Old 04-26-2005, 05:58 PM
99blancoSS's Avatar
hehehe, had a huge long screw driver to reach down from the top. Some times when your a kid you gotta do what you gotta do.
