Lid and engine code
Lid and engine code
yesterday i put on an SLP lid, about 20 minutes of driving later the check engine light came on. Has this happened to any of you, could it be the intake temp sensor?
You could always reset your computer and see if it goes away. Here is what I did a couple years ago when I had the same problem:
1. Turn key on but don't start car.
2. Pull PCM BAT and PCM IGN fuses in engine compartment.
3. Wait a few minutes.
4. Turn ignition off.
5. Replace fuses.
Hope this works.
5. Replace fuses.
Hope this works.
