MAF 75mm to 85 wiring ???
I am adding a Z06 MAF to my 99 Vette. What wiring do I
need to change to use the AIT sensor. Do I need to drill my
airbridge to add a AIT sensor? I have a Z06 t-body and I thought
the air inlet sensor was relocated into the t-body? What is the easiest
way to convert 3 pin to 5 pin MAF?
Thanks!
Thanks!
I have a 99 Vette with the 3 pin MAF wiring harness. The 85mm
Z06 MAF has a 5 pin connector. My MAF has a 3" long connector
that looks like it adapts 5 pin to 3 pin....BUT, my 3 pin connector
doesn't work with it (new motor install,I'll recheck the wiring). My
question is....Since I have a Z06 t-body, how do I connect to the
AIT sensor? It seems like a aftermarket adapter should connect
to the 5 pin, then split to two connectors, MAF and AIT sensors.
Thanks!
Thanks!
Originally Posted by WS6FirebirdTA00
let me get this strait, you wanna put a new maf on that has the IAT sensor in the TB? is that right? if so get the male end off a wrecked z06 or see if u can order one and put the pins off your IAT sensor now into it and be done, will look stock
Possible Scammer - Buyer Beware - Issues Unresolved
Originally Posted by jimmyblue
Casper's sells a 5-wire adaptor that plugs up to the
separate MAF and IAT harnesses in F-bodies and
older 'Vettes.
older 'Vettes.
I think I have an extra adapter you can have...
E-mail me if interested.
Thanks,
Russ
scantech@bellsouth.net
Thanks,
Russ
