EGR blockoff plate
Old 05-10-2005, 01:16 AM
ArcticZ28's Avatar
Default EGR blockoff plate
Anyone know where I could get the EGR blockoff plate for the EGR port on an LS6 intake with the EGR provision? All I can find are the plates that block off the EGR port on the headers. Thanks.
Old 05-10-2005, 01:27 AM
blkZ28spt's Avatar
You aren't looking for a block-off plate, you want a freeze plug. I think it's 1 3/8". (don't quote me on that, it's been awhile) Should be able to find one at a local auto parts store.
I checked, I'm almost positive it's a 1 3/8" plug.
Old 05-10-2005, 01:45 AM
ArcticZ28's Avatar
Excellent, thanks alot for checking for me.
Old 05-10-2005, 08:59 AM
1madss's Avatar
Take a look at this post.
https://ls1tech.com/forums/generation-iii-external-engine/46575-need-plate-block-egr-off-manifold.html
Old 05-10-2005, 09:07 AM
777's Avatar
ls1speed.com (speedinc) sells them...
Old 05-10-2005, 12:12 PM
94formulabird's Avatar
1.50 freeze plug and your good to go
Old 05-10-2005, 12:44 PM
ArcticZ28's Avatar
Originally Posted by 1madss
In that thread they say to use a 35 mm freeze plug. Which one should I use, a 1 3/8" or a 35mm?
Old 05-10-2005, 01:03 PM
ArcticZ28's Avatar
Also, what do I do with the electrical connection that used to go to the EGR once I remove it? Do I just tape it down somewhere out of sight?
Old 05-10-2005, 01:08 PM
1madss's Avatar
I used the 35mm. The other may work I just have not tried that size personally. The connection can just be taped up. Mine is just tucked back out of the way.
Old 05-10-2005, 01:13 PM
99Hawk262's Avatar
1 3/8" fits great, just did it to mine. I also taped the connection up and let it hang. I'll tuck it out of the way one of these days. Just expand the freeze plug using a vice and a wrench until if fits real snug, then tighten her down the rest of the way. Otherwise, it'll want to spin on you.
Old 05-10-2005, 01:27 PM
99FormulaWs6's Avatar
1-3/8 and 35mm are the same size,
1.375*25.4=34.925
Old 05-10-2005, 06:04 PM
00badfnta's Avatar
This will help...http://www.ls1camaro.net/sections.ph...ticle&artid=70
This is what I used for help.
