TPIS 1200 CFM throttlebody
Old 05-12-2005, 05:43 AM
jaberwaki's Avatar
Default TPIS 1200 CFM throttlebody
searched, but found no info on this piece...
whats the deal?
does it work as claimed?
or is it snake oil?
Old 05-12-2005, 12:45 PM
triumphman's Avatar
T.p.i.s. has both billet 90mm throttle bodys for ls-2 and fast intakes and billet oval throttle bodys for modified ls-6 intakes Their phone # is 952-448-6021.
Old 05-13-2005, 04:48 AM
jaberwaki's Avatar
What i am looking for here is anyone who has dyno (or track proven) this set up...
even if you buy the custom intake with it, it claims more hp them switching to lsx 90 has proved and it costs less (total)
so if i can make more,or even the same, amount of hp switching to this set up and save a few hundred bucks....
i will
Old 05-13-2005, 10:20 AM
bmfcamaro's Avatar
i think that the fast is better. the tpis intake just seems like it would not be as strong since they put there own neck on a cut off ls6 manifold. plus the fast is 3 piece for porting. i would use there throttle body though which i am. i was very impressed with the fast intake when i recieved it.
Old 05-13-2005, 10:26 PM
jaberwaki's Avatar
as long as they plastic weld it write there should be no strength issue...
i just wanna know if any one has actually dynoed this peice?
Old 05-13-2005, 11:21 PM
bmfcamaro's Avatar
i know that they have posted some numbers. search for tpis screenname not sure what it is just do a little searching and you will find it. it has been a while though.
Old 05-13-2005, 11:33 PM
jaberwaki's Avatar
i been searching for 2 days now...have only found one other thread that was asking the same thing... but no answer was given then either..
