Help!! Y pipe banging problems
Old 05-15-2005, 02:14 PM
SLPSS01's Avatar
Default Help!! Y pipe banging problems
I know this topic has probably been beaten to death so I apologize but I need some help.
I have Pacesetters on my 01 SS with the Texas Speed Y pipe. It sounds like it's hit or miss with these things and apparently I am one of the unlucky ones.
I installed the Mufflex bump stop hanger which seemed to help a bit with normal acceleration but the Y is still banging on the driver side under hard acceleration. I've only got about 1/4" clearance between the top of the pipe and the underside of the car. In fact the clamp of the Mufflex piece may actually be what's still hitting.
Sorry if I stole someone's picture here but does the Pacesetter Y come like it's pictured below with the flat spots ?
Anyone using the Pacesetter Y recommend it ? How well does it fit ?
If this would solve my problem someone will get a great deal on my practically brand new TSP Y pipe.
This is the only part of the Y that is hitting, if I took this to an exhaust shop could they put a flat spot on the section of pipe which is hitting (circled) without deforming the end of the pipe?
I tried doing it in the vice and banging it with a mallet but neither one is working very well, both methods are deforming the end of the pipe which I need to keep round to fit into the rest of the Y pipe.
I'm really not sure the best way to go about this. I'd really appreciate any advice you guys have to offer.
Thanks
Old 05-15-2005, 02:16 PM
cyphur's Avatar
try moving the bumpstop rubber piece closer to the chassis, looks like its not positioned optimally from the pic.
Old 05-15-2005, 02:26 PM
SLPSS01's Avatar
Here is a better pic of the hanger
Old 05-15-2005, 11:12 PM
transAm-98's Avatar
i had that problem with my qtp's. if i put it low enough that it didn't bang my floor, than it would scrape on everything. if i put high enough to keep it from scraping then it would bang (i even took a sledge hammer to floor pan to help, but it didn't help much). i just put a poly motor mount on my drivers side and it solved the problem. it idles way smoother and it feels a lot better when i launch. i can't wait to do my passanger side once i have the patience (it's not a very fun job to do)
Old 05-16-2005, 03:32 PM
HouseWS6's Avatar
where did you get that? or did you make it? my y pipe is driving me apeshit..
Old 05-17-2005, 12:45 AM
Nick D's Avatar
prothane poly motor mounts at:
www.thunderracing.com
Problem will be solved. Period.
Old 05-17-2005, 12:58 AM
rawlitogut's Avatar
Mine stop banging after awhile. What I did is look for marks to where its was hitting. I stuck a bar and pushed down on it. Until it went away.
Old 05-17-2005, 01:17 AM
HouseWS6's Avatar
where are you guys getting the mufflex hanger??
Old 05-17-2005, 08:17 AM
Chevy01SS's Avatar
Thunder racing sells the hanger. As far as getting mine to work I had to reposition it and drill a new hole into the floorpan. I also did the the hose mod and clamps while I was there and now I have no banging. ******* stupid that somebody can't design a Y-pipe for these things that doesn't have to be jimmy rigged.
Old 05-17-2005, 09:31 AM
SLPSS01's Avatar
That's what I thought I was getting with the TSP Y pipe.
Old 05-17-2005, 09:35 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Guys with Y-pipe bangin' problems.
Shove a piece of rigid insulation with the shiny heat resistant outer layer (yes, the Home Depot stuff!) between your Y-pipe and the floorboard where the banging occurs. Do this and your problems will go away. It's so simple, yet so many people won't do it.
Old 05-17-2005, 10:23 AM
99RedGhost's Avatar
to fix mine I got the whole damn thing welded except for the header collectors. That fixed all of my problems with the TSP Y-pipe.
Old 05-17-2005, 03:17 PM
Chevy01SS's Avatar
Thats because it looks like ****, and when you pay this amount of money for a car and the associated parts you want them to fit and look clean. I ended up doing it to fix my problems, but I'm still not happy with it.
Old 05-17-2005, 03:24 PM
!LS1 11 Second Club
Is your car a showcar with mirrors under it?
Going after the Riddler?
I understand your frustration.
Old 05-17-2005, 03:54 PM
Tally TransAm's Avatar
i usually just shove a piece of heater hose between the ypipe and whereever its hitting
Old 05-17-2005, 05:58 PM
OldeSkool's Avatar
What he said!
Old 05-17-2005, 06:02 PM
OldeSkool's Avatar
Yeah, SLP did... but look where it got em, everybody crying bloody murder because theres no ground clearance. If you want a 3 inch y-pipe you're going to have to give up ground clearance, or deal with banging, or put in poly motor mounts. Personally, i direct my anger towards GM engineers for not making decent exhaust provisions on these cars, i mean, look under a mustang sometime! Holy exhaust clearance batman!
Old 05-18-2005, 09:26 AM
Jeff2002WS6's Avatar
I recently almost completely cured my problems with the Jet hots banging in almost the same place. I loosened all the studs in my headers, loosend all my band clamps on my ENTIRE exhaust system. I got some 1 inch thick pieces of wood and wedged them in between all the spots where the pipe was close. Then I took my floor jack and jacked up the lowest spot in the exhaust a little which was the passenger side on mine after adding all the wedges. I re-tightend everything starting all the way at the back with the cat back and moved my way foward to the headers. Took out the wedges and problem is 95% gone. It only bangs now when I stomp on it from a dead stop, and it is only a quick hit, and it hits at the top of 1st at my 1-2 shift. I can live with this but will try and adjust my Muflex Bump Stop. I do plan on adding the poly mounts I have sitting on the shelf some day.
Old 05-18-2005, 09:32 AM
SLPSS01's Avatar
so you're the reason I couldn't regsiter with that user name -lol
-Nick D.
Old 05-18-2005, 10:23 AM
FinalTA's Avatar
I feel like mine may be banging on the torque arm It is close to the floor board in a few spots, but seems right up against the torque arm. It bangs/rubs under "spirited" acceleration...
Quick Reply: Help!! Y pipe banging problems
