NEED HELP...pls!
NEED HELP...pls!
I am in the process of upgrading to the ls6 intake and am ordering the front coolant pipe and rear coolant plugs. The part #'s I got from ls1howto.com were: 12568478 for the front pipe, and 12562788 for the plugs. My gm parts guy stated the coolant pipe part # had changed, and it still lists the part as a coolant pipe, but he had a new part # for the rear coolant plugs as well, but he stated they were called "caps". anyone know if these are indeed what I need. thx again.
btw, the new part # he gave me for the "caps" is 12570678, and he said they were $4.64 each, sound right??
i just bought my ls6 intake and it came with the rear block off plates or caps. it also came with the front coolant pipe. the part #'s you listed are the part #'s on my parts sheet. your gm guy is right though, i don't know if they are called caps, but the block off plates do look alot like caps.
