Spark Plugs
Old 05-18-2005, 08:27 PM
bandit01ws6's Avatar
Question Spark Plugs
I have a mostly stock 01 ws6 what spark plugs should I use and what exactly am i gettin my self into. Ive done LT1 in the past Hopefully this is easier
Old 05-18-2005, 08:32 PM
SilverM6SS's Avatar
NGK TR55s. Easy install, get all from up top except for #8.
Joe
Old 05-18-2005, 08:38 PM
Lss1350's Avatar
I wish I could remember my install, I did mine about a year ago when I did my headers. I dont recall having to do the #8 plug from the bottom?
-j
Old 05-18-2005, 08:52 PM
nostyta's Avatar
Check out Jerami's FAQ in the New LS1 owners forum, has a complete step by step guide.
Old 05-18-2005, 09:59 PM
Gamefan008's Avatar
Yeah, for #8 i had to crawl under the car and reach up past the header collector.
it's really not all that bad though
Old 05-19-2005, 09:09 AM
Tallon535's Avatar
-j
If you changed the plugs when you had the manifolds/headers off the car you could probably reach the number 8 plug from the top. Once the headers are on, though it is MUCH easier to just jack the car and go from the bottom. I just changed my plugs last weekend.
Old 05-19-2005, 09:33 AM
hifi dream's Avatar
I did plugs on my Formula a few weeks ago and followed the steps from install university. Once I got the AIR tubes off and the coil pack moved out of the way the install wasn't that bad. Number 8 is a pain, but I got it from the top fine (just have to use a 1" swivel).
Old 05-19-2005, 10:18 AM
777's Avatar
98's don't have it as easy though
Old 05-19-2005, 11:17 AM
hifi dream's Avatar
When I did the plugs on the 98 TA I used to have I didn't take the individual coil packs off. Made the job really hard, but I managed to get it done in...oh I don't know....6 hours
Old 05-19-2005, 02:47 PM
ls1charged's Avatar
NGK TR6's and the only 1 that sucks is the pass rear 1
ls1charged's Avatar
dude it seriously takes a half hour to change plugs if you know what your doing.
Old 05-19-2005, 09:24 PM
ArcticZ28's Avatar
You should not use TR6's on a mostly stock car. They perform in a colder heat range, making them optimal for use with nitrous. The TR55's are going to give you best performance and make more sense to go with.
Old 05-20-2005, 05:25 PM
mustgofasster's Avatar
Where Do You Gap Them At? Or Do You Just Leave Them Alone? And What About Wires, Is It Dumb To Put 8.5mm Msd On A Moslty Stock Car?
Old 05-21-2005, 05:17 PM
NateLS1's Avatar
I just did TR55's last week, I gapped them at .050 I think. Stock is .060 IFRC. With that being said, I consisitently hit 108 in the 1/4. up from 105 - 106, and all I did were the plugs.
It's a pain in the *** job but just get'er done!
Old 05-21-2005, 10:43 PM
ArcticZ28's Avatar
Most people gap at .045-.050. I just got some TR55's and gapped them somewhere in that range. Plugs will definitely help you a bit with idle if it's been a while since you changed them. No need to upgrade the wires unless you are having problems with teh stockers. I myself was so I picked up a set of MSD's. It's hard to really say if they help anything but they sure don't hurt and are more cost effective than getting a set of stock wires from the dealer.
Old 05-22-2005, 02:27 AM
Redneck Z's Avatar
If you have changed LT1 plugs, then doing the ls1 will seem easy. Just make sure you have all the right tools. I found it handy to have a long ratchet and also a short swivel ratchet. I also used both a 1'' and 3" extension with a swivel. Some like doing #8 from the top and others like to do it from below. I would jack the car up so you can try both and see what works for you. My first time took a few hours with some breaks here and there. I'm sure it would be alot faster next time. Good luck.
Old 05-22-2005, 02:34 AM
jaredwayt's Avatar
gap @.050, use tr55(ngk), should take about 30 min, dont bother taking off the coil packs, #8 is a pain but aint that bad at all.
Old 05-22-2005, 04:03 AM
black00TA's Avatar
8 is easy form underside, no need to remove coil, just remove emissions hookup on header and its simple.
