write up on replacing motor mounts?
Originally Posted by ArcticZ28
Not that I know of. Are you completely in the dark about it or just have one or two questions to clear up?
Originally Posted by 72sub
I used this one: http://www.humanoidms.com/howtos/polymount.doc
i just did mine and wow. lining them up is a bastard. prepare to get pissed. just make sure that the mount is in the clam shell straight or lining up will be an issue. good luck. if you have questions you can pm me.
Patience will be your greatest tool.
See also the following threads:
https://ls1tech.com/forums/generation-iii-internal-engine/317555-poly-motor-mounts.html
https://ls1tech.com/forums/generation-iii-external-engine/323671-help-putting-motor-mount-bolt-trough.html
