Ahhhh... o2 sensor seized... ideas?
Old 05-23-2005, 04:32 PM
BrandonSS's Avatar
Default Ahhhh... o2 sensor seized... ideas?
I simply cant get this damn thing out. I dont have an impact or anything so how the hell can I get this out of the header? Its just flat out stuck.
Old 05-23-2005, 05:02 PM
blkZ28spt's Avatar
Get a ratchet or something with the O2 socket nice and snug on the sensor. Use a jack (i use my old/little 2.5 ton jack) to lift up on the ratchet's handle. I've used that a few times and it's always come through.
Old 05-23-2005, 05:07 PM
DWillTA's Avatar
Are you replacing the O2? You may try a little bit of heat from torch set or propane household torch. Shouldn't bother anything as long as you stay away from the wires.
Old 05-23-2005, 06:59 PM
BrandonSS's Avatar
Thats what I did and it worked. Let it soak more in OB blaster and jacked away... ta-da.
Thanks guys!
Old 10-19-2007, 05:50 PM
Tram's Avatar
Yeh, the jack trick works like a charm..
Old 10-19-2007, 11:02 PM
SoCal01z28's Avatar
this happens to me all the time at work, completely soak it down with liquid wrench then get something with some leverage to work it back and forth
