how to unstick a stuck O2 sensor?????
I have TTS coated headers. The front 02 is stuck
I used PB Blaster and a the 02 socket, then a 7/8 wrench, then vice grips, now I just have a siezed 02 with a stripped head.
And yes Anti-sieze was used when installed
since it is stripped, you may want to see if you can get an easy-out that will fit.
you can get them @ sears. they are similar to a socket but are 'rifled' so that they bite in to the bolt head deeper the hard you have to turn.
