How hard is it to repair broken bolts on stock manifolds?
I'm looking for some 01,02 manifolds to use with my Phamspeed kit, but all the ones on ebay have at least one of the bolts that go to the Y pipe broken off. How hard a fix is that? Can I just drill out the hole and weld a new one in?
Thanks,
Brad
Thanks,
Brad
You can drill out and the hole carefully and re-thread it if you want. I tried doing that on a couple bolts that broke off on my manifold-to-header connections but those F#$%ing SOB's were absolutely ridiculous in getting out. I ended up just drilling out the hole completely killing the threads and using a nut and bolt combo.
yes...i tried and tried...those things would not come out for anything...i used my best set of vice grips and **** loads of pb blaster and the pliers were just eating the metal away...they would not turn...period...they were rusted pretty good though...i just ended up finding some that were ok...i also used the bolt/nut on one of them...the only prob is..on two (i think) you cant do that bc the hole is right against the actual manifold and there would be no room to put a nut on the backside...i belive its on the passgr side...you will see one of them there is no way to get a nut on it..due to it being right up agains the manifold body.
matt
matt
matt
matt
