PICS of 2001+ MAF (w/screen) and ZO6 MAF
Does anyone have pics of these for comparsion.
The reason I am asking is I took the screen out of my factory 2001 MAF (2001 Corvette). I had heard the only differnce between the 2001 screened MAF and the ZO6 MAF was the "screen"...
I just found out that the MAF on a 2001 C5 is the same (85mm) as the ZO6 except the screen. The 2002+ ZO6 MAF is also screen-less and does NOT have the front air-foil that the 2001s have....
I know, I was just giving you **** because I have followed the progression of your car and the changes you have made. I can only thank you for sharing what you have learned. I have certainly learned from you. I have had some of the same ideas on what might work that you had, however I can't afford to make changes or mistakes.
