Will a LT1 Cat Back fit a LS1 ?
Old 06-03-2005, 01:22 PM
Van5150's Avatar
Default Will a LT1 Cat Back fit a LS1 ?
I have a Magaflow Cat Back, single cat. Anyone know what it will take to bolt up to my '00 Formula ?
Old 06-03-2005, 03:44 PM
Scully's Avatar
man i don't know what to tell you, but i had a 96 z and put a mufflex off of a 00z on and we didn't have to modify anything.
Old 06-03-2005, 03:47 PM
12secSS's Avatar
You might have to trim off some extra tubing from the LT1 exhaust. The LS1 uses a slip fit that is a bit farther back then some LT1s, all you would need is to cut it to fit the LS1 Y-pipe and use a clamp of the correct size. Either a 2.5" or 3" would work.
Old 06-03-2005, 04:30 PM
Z-286speed's Avatar
If the pipe does not slip on, you could go down to the exhaust shop and have them expand the pipe for a slip fit. Real cheap and easy to weld up with the slip fit.
Old 06-03-2005, 05:50 PM
Van5150's Avatar
Thankie guys., much appreciated.
