who's car is this? I love the exhaust and want some info
http://www.ls1sounds.com/true_duals/...peedIncTDs.AVI
http://www.ls1sounds.com/true_duals/...ht-driveby.AVI
kooks 1 3/4", OR X-pipe, Magnaflow mufflers...need more info. I love the way this sounds and would like to do something close to it.
pics?
pics?
Originally Posted by Screamin_Z
I can see it says SpeedINC TD...I'm guessing it has that but I'm wondering the other mods.
That doesnt seem to have any distinction of a cam or anything so I'm sure its probably a full bolt-on SS. Your car should sound the same w/ that setup since you have an 01. Good luck
http://www.ls1sounds.com/pics/speed-...dIncTDs_01.jpg
http://www.ls1sounds.com/pics/speed-...dIncTDs_02.jpg
If I remember correctly I believe the system was $1,995 but am not 100% sure. I do know however it was over the $1,200 mark.
thanks, those are SLP tips on MeentSS02 car? I looked on thier site and couldn't find them.
I could have sworn i seen them there before. LS1speed.com no longer has the TD's on there site but I'm sure if you goive them a call and/or Contact Larry Mike or Tom they can get you some info fast.
You haveta look under the 1998-2002 SLP CAMARO SS section for those particular tips. SLP Has Quad tips as well. Just gotta search around
SN95 Director
I've found quad tips but not the (long) dual tips, back to ebay...
Look under the SLP Cars, they have them i just saw them loook by where you can get Restoration or Replacement parts for the SLP SS's or the Firehawks its right there. Its further down all the way to the left. not the 1998-2002 F-body selection your looking under Camaro SS only
1 Post
Originally Posted by 02WS6Bird
Speed Inc TD's thats for sure. It's a 2002 so it has the Vortech Truck Cam and the LS6 intake. To me from hearing a 2000 LS1 w/ LT's and GMMG to hearing my 02 LS1 w/ LT's and GMMG the sound is distinctly different, much more crisp and has more muscel car note to it- has very small lope to it.
Idont understand what you are saying. The only way my car will have more of a muscle car note note to it, is if i add add a cam. remember your 02 cam is smaller then the 00'. I think this is an unfar statement. Im not saying either sounds better, im just saying, how can you say something like that? i dont think this is a fair staement
Originally Posted by KrazyDan
Sooo, your saying your car sounds better then any other year?
98-00
Duration@.050 198.86 intake 209.25 exhaust
Lift .498 intake .497 exhausts
LSA 119.45
-35.1° Valve Overlap
01-02
Duration@.050 196.37 intake 208.72 exhaust
Lift .464 intake .479 exhausts
LSA 115.92
-30° Valve Overlap
From my understanding Valve overlap can help determine cam lope and from hearing severa different cammed cars, 5° is a noticeable difference. For instance one could compare the MTI Stealth series cams (220/220 .581/.581 115LSA or 224/220 .581/.581 116LSA) @ -10° overlap and the TR-224 on a 114LSA (224/224 .563/.563 114LSA) @ -4° overlap. There is no way you can say that these 2 cams do not sound different at all levels by any means AT ALL. These cams are also remotely similar size. (this is the best way i felt I could compare) I hope this makes sense.
MASS seller approved
PM or Email me if you are interested in the blemished tip.
