ls6 intake
Well those people are dumbasses then. The LS6 intake is a direct swap on the LS1 motor. The only thing you need is coolant plugs for the heads and a coolant crossover pipe that goes under the TB and connects from the driver to passenger head. These pieces I mentioned are less than $50 total.
Also there's a really good install writeup on the intake...search for JMX's install guide.
Originally Posted by SCREAMIN
Should gain anywhere from 15-20 rwhp?
Stock or bolt ons only you'll probably only see 10-15 rwhp, if I had to guess..
