Codes after header install..need help..
ok these are the codes i am getting after i installed my headers...there are 4 of them...
PO-131 Bank 1 sensor 1 Low Voltage
PO-140 Bank 1 sensor 2 No activity detected
PO-151 Bank 2 sensor 1 low voltage
PO-160 Bank 2 sensor 2 no activity detected
Im assuming these are 02 sensor codes..I got extensions for the front 2 02 sensors and i got the codes deleted for the back ones so what the hell is the problem?
You shouldn't have any sensor 2 codes. Who ever deleted your rear O2s forgot those. As far as the low voltage codes... mabye a bad O2 extension? Usually low voltage means bad O2 sensor.
