TD sounds like crap
TD sounds like crap
I got the local shop to run 2 1/2 from the cats all the way back and put two bullets on. It sounds like a redneck truck. It also feels slower than it did with a flowmaster 80 series I had on it before and the stock pipes. Can not having an X or H be causing the sound problem? Should I chop of the bullets and get some real mufflers?
HELP
HELP
HELP
HELP
You absolutely need some kind of balance pipe...H or X. The truck sound is most likely because you don't have a balance pipe.
Additionally, the exhaust shop probably crush bent the pipe, which isn't the best for performance.
I would add an H pipe because it will be the easiest to do and it will sound good. An x-pipe tends to help with power a little bit and sounds pretty good too...but you really need to build the exhaust around the x-pipe on the f-bodies because it only fits in one spot.
What he said ^^^
Yes, you NEED the X or H pipe for good sound. Getting a crossover pipe to connect the two sides shouldn't be too hard. Assuming you are on stock exhaust right now...keep in mind for when you get headers that TSP's rumbler X system is a very affordable exhaust. I saw this thread title and just had to see WTF was going on. I'm glad this is what it was.
