what do i need/tips? QTP LT install
hey i just bought a set of QTP LT's with AIR fittings and was wondering if all i need was LT y pipe, o2 extensions, header gaskets, and o2 simms? for the install, also can you guys give me any tips or hints for the install that will make it easier ??? any info would be appreciated thanks a lot -Josh
SSU's Drunk Typing Whore
Everthing is pretty much covered in jrp's sticky. Anyway, a lift is a big help, 10mm gear wrench is good to have. If you can get a friend to help you, do so. Might want some stage 8 bolts along with some nice band clamps. The friend will also come in handy when you put the oil dipstick tube back in as well. Good luck with the install.
