o2 sensor ? and JET HOT question
two questions....how do you remove the o2 sensors that are in the manifolds and is the "bung" the hole that the sensors go into on new headers...
also...LM performance has the JET HOT headers for $499....how do these headers stack up all around???
THANKS
THANKS
Spend the few extra bucks and get Pacesetters. Overall, the best bang for your buck and comperatively to all the rest easy to install; not that I am sayinge install is easy. You still have to drop the K-member. Next step up would be KOOK's LT's. Call Texas-Speed.com I got mine from them w/ HiFlo Cats and Y pipe for a little over 8 ben franklin's.
I am runnin the hookers from jet hot. and have no problems. didnt have to lower the k memeber and they sound great.and the o2's are somtimes a PITA to get out. just soak it with wd40 let it sit for a while then try with a good wrench.
