are corvette and f-body 02 sensors the same??
Old 07-18-2005, 02:30 PM
jimmyp's Avatar
Default are corvette and f-body 02 sensors the same??
just wondering if the front ones are the same?
Old 07-18-2005, 02:46 PM
technical's Avatar
While they basically are interchangible, they are different part numbers I believe. At least for the front heated O2's. People tend to recommend the corvette sensors over the F-body especially when using long tube headers.
Old 07-18-2005, 02:47 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Old 07-18-2005, 02:51 PM
777's Avatar
I'd get the corvette ones. They last longer supposivly
Old 07-18-2005, 04:52 PM
jimmyp's Avatar
ok thanks guys...i was missing one and got a pair of vette ones off ebay. Then I noticed the part numbers were different and figured i would check.
thanks again!!
Old 07-19-2005, 12:10 PM
Nasty N8's Avatar
The front o2 plugs are completely different from F-body to Vette. The Vette uses the Old LT1 style flat plug and the F-body uses the square plug.
Nate
Old 07-19-2005, 02:50 PM
jimmyp's Avatar
well here is the vette plug I just won on ebay and from the pic it looks the same as my f-body one:
http://i18.ebayimg.com/02/i/04/70/94/7e_1_b.JPG
I got 2 vette ones...can I still run them with my f-body harnesss/pcm then or not??
Old 07-19-2005, 02:55 PM
12secSS's Avatar
The O2 sensor itself it the same one used in many closed loop applications, the reason for the part number difference is the length of wire used in the harness and/or the mating plug. There is not true performance or longevity benefit using one or the other. Corvette O2s have longer wire harnesses, hence why some opt to run those with LTs.
