locations of 02 sensors and diverter tube
I think i can locate the 2 with the big sensors but not the
other two. Do they terminate at trans and engine block?
Do I need to remove starter to see diverter? I am just doing
preliminary look and see I prbably need to be a lot higher
just for a look.I guess I'll start the header install after the
heat wave.
John
heat wave.
John
Diverter tube??
All four O2's sensors are essentially identical. The only difference may be the length of wire on them required to reach. With stock exhaust the first two sensors are pretty far up there. You won't have to even look at the starter (well, maybe, lol) for a header swap. Will you be using jack stands? If so, remember that you will need room to get the headers near vertical (for most longtubes). The more room you have the maneuver the headers, the easier it will be to slide them in there.
