85mm maf
Old 07-29-2005, 12:10 AM
Magnet's Avatar
Default 85mm maf
hey guys i happen to pick up a 85mm granatelli motorsports maf in a lot of parts i bought.....and i was wonderin what kind of gains would i expect with it and a 85mm lid? would i gain ANYTHING over a stocker and a normal lid?
Old 07-29-2005, 12:22 AM
Magnet's Avatar
i know you all know...please help
Old 07-29-2005, 01:26 AM
BOONE's Avatar
Default maf and lid
A maf and lid you will surely gain hp and notice it, but i have heard that, that particular maf is troublesome with throwing codes on some cars or something.
Hopefully someone else will chime in, that knows more. If you get a lid, get a quality one, as some dont seal well and suck dirt.
Old 07-29-2005, 01:42 AM
98Grnz28's Avatar
85mm granatelli motorsports Maf sucks I had one it threw a check engine light everytime I drove my car.
Magnet- Do you still need those stickers? If so I will give them too you. Just give me a address.
Old 07-29-2005, 06:44 AM
LS1TECH Sponsor
Steve Burger's Avatar
Just returned an 85mm GMAF because we could not tune it.
Old 07-29-2005, 12:31 PM
JonB's Avatar
I have't heard to many good things about there maf's evey once and a while someone has a good feedback. But since you have it i'd give it a shot and see how it does. Anyone happen to see the latest super chevy where they put a granatelli maf on a LT1 and gained 30+hp and like 22ft-lbs. This is an example of a good feedback but most mag are sponsered or get money for useing certain products such as granatelli. I beleive they did the baseline dyno with a dirty air filter which is why they got such good results. You should have seen this filter it looked like it was covered in mud and i believe thats why they got such good reults because they changed the filter not from the maf.
Old 07-29-2005, 02:37 PM
Magnet's Avatar
yea i saw that article....i have never heard of such good results from one...and i figured they were getting spornsored for it......i wouldnt expect anything like but i just wonderin if there would be any gain over a regualr slp lid and stock maf and a 85mm and granetelli 85mm maf.....
Old 07-29-2005, 02:56 PM
JonB's Avatar
There are gains a few people have seen results its a real hit or miss thing. I would just swap it and see what happens if you start pinging take it off if not leave it. I'm not sure if you allready have a lid but if you don't just hook it to the stock intake system if you already have a lid you will need some fernco or something to hook it up you actually might need it with the stock system im not sure i don't really remember if there is any give to the stock intake but there was no way it was going into my lid so i just sliped some fernco over the lid and the maf.
Old 07-29-2005, 03:33 PM
Bill's 02 Z-28 SS's Avatar
Hi Folks
I have the ZO6 MAF (85MM) without a screen. It appears to work OK, I actually got a copy of a 2003 ZO6 tables and installed them in my PCM. The numbers appear to be normal but I am not sure that I gained or lost an performance. I did it because of the 90MM TB and intake - I could see having a 75MM MAF with that setup. I am not sure it helped or hurt. Remember most the folks will tell you not to waste your money on it but it is your call.
Bill
Old 07-29-2005, 03:34 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
I used a PACE 85mm (ls1 calibrated) Z06 MAF. Worked fine.
Old 07-29-2005, 05:55 PM
Phoenix 5.7's Avatar
the GMAF i have is a POS. i got an ses within like 2 days of running it. put the stocker back on. i have heard good things about the Z06 maf recalabrated for an LS1 though
Old 07-29-2005, 06:35 PM
sunsetta's Avatar
Anything good or bad about the 85mm SLP Maf. Was thinking about getting one. Give me some input. Thanks.
Old 07-29-2005, 07:24 PM
With your setup why would want the 85M MAF? - it appears you still have the 75M TB. no advantage and only problems
Bill
Old 07-29-2005, 09:35 PM
!LS1 11 Second Club
Yeah, unless you have a FAST 90mm intake, there's no reason to take off the stock MAF. It's your best MAF.
Old 07-30-2005, 12:27 AM
RrCoX22's Avatar
I put the SLP 85mm MAF on cuz I screwed my stocky up by descreening mine. With the SLP MAF there was a noticable difference compared to mine descreened one and the installation took about 5 mins. and haven't had any probs. since. I don't know if it fits well with the stock bellow but I went out & bought the cheap fernco one and it works fine.
Old 07-30-2005, 06:03 AM
beardWS6's Avatar
I have the Gran 85mm and no problems at all. I run the 90mmLSX set-up with in. Car in Sig!
