Help running the wire for the electric cutout
whats the best place to run the wire from inside the car at the switch to the cutout itself? any holes under the center console?
Take off console, get a coathanger, attatch the wire to the coathanger. Put the coathanger under the carpet and run it to the opening under the passenger side rear seat. Reach your hand under the carpet and pull out the plug in the floorboard. Poke a hole in this and put the wire through it.Re-install plug, pull as much wire as needed out. Seal the plug with silicon afterwards. Very easy.
