PS pulley install questions.
Old 08-24-2005, 08:49 PM
LS1FIRE's Avatar
Default PS pulley install questions.
Hello. I am going to be swapping out my powersteering pulley to a turnone pulley. I was thinking if the threads on the head were the powersteering bracket is bolted on too can be damged from the pressure of the powersteering puller pulling on the pulley to remove it?
Old 08-25-2005, 06:07 PM
LS1FIRE's Avatar
Anyone?
Old 08-25-2005, 06:51 PM
Grimes's Avatar
naw, I dont think they will pull out or anything.
Do you have an under drive pulley? if so, you may not have enough power steering pressure with the ud pulley, and and turn one installed. Just a heads up!
Old 08-25-2005, 07:36 PM
LS1FIRE's Avatar
Yes i have a underdrive pulley. Why would there be a problem running the turn one pulley? Its the same size as stock.
