Q about new gauge cluster
Old 08-24-2005, 09:45 PM
H/C LS6Z's Avatar
Default Q about new gauge cluster
I just installed a new gauge cluster because my old one just had some odd issues. Well I got this new one in just fine but there's one thing thats troubling....
Wehn I turn the ignition to run all the lights on the gauges light up i.e odometer, ars off, security etc etc... One light doesn't come that is most important, the SES light. I knew on my old cluster when I turned the ignition on to run the SES would light up with all the others but when I start the car it goes off. On the new one it deosn't even come on when I turn the ignition to run?
Is there a way to check to see if maybe just the bulb is burned out? What can I do to check and see if it will work?
Old 08-25-2005, 02:05 PM
H/C LS6Z's Avatar
anyone?....
Old 08-25-2005, 02:22 PM
zfastss's Avatar
my best guess would be just a burnt out bulb. Do you still have the old cluster? If you do, I think you can just swap out the bulbs for the SES light. If you don't still have the cluster, just pick up a pack of bulbs (194 type) I think, shouldn't be more than $2-$3.
Good luck, hope this helps
Old 08-25-2005, 03:59 PM
Sawzall and Welder Mod
Whistler's Avatar
What year is the car you put the cluster in? 98 takes a different cluster than 99-up
Old 08-25-2005, 06:59 PM
H/C LS6Z's Avatar
I put it in my 2000 SS, the gauge cluster allegedly came out of a 00 Z
Old 09-05-2005, 10:04 PM
H/C LS6Z's Avatar
Well I pulled the other light out of my old gauge cluster and swapped it into my new one and the SES light still didn't come on when I turned the ignition on
so where do I go from here? how do I get my SES light to work?
Old 09-06-2005, 05:52 PM
H/C LS6Z's Avatar
anyone?....
