pacesetter f-body AIR tube probs? egr too?
Closed ex-Sponsor Account
helping w/ cam/headers on buddies 99 SS, cam install went together w/ no glitches other than the pita oil pump p/u bolt(i'm from the used to the c5 stuff), got the ss onto the lift, pc'ers bolted right in after sawzalling the casting on the dr. side of block, installed the plugs,wires,packs, then the AIR tubes are 180 deg off, why? i could cut the fittings on the oem side and use hose to hook them up or mill block off plates on the brideport(uncle has one), but don't want to throw codes for emmis test; same deal w/ egr, way off thanks for the help
i think the headers are for the 00-02 f-bodies, i know the c5 AIR system runs 97-2000 and 2001-2004, prolly the same deal and psetter just put the wrong headers in the right box, what's 'ET' style headers?
I had the same problem with my hooker headers on a 2000. I ended up yanking the EGR and Air off. I was tired from the header install and I have an upcoming install with an LS6 intake (non-egr) anyways.
Location: Live Oak, FL - in the woods where the creatures lurk.
Not sure what's up-I installed mine a week ago and the AIR was simple to hook up with the supplied gaskets and bolts. The hoses/check valves had sufficient reach to bolt up with no problems. Pretty much the same with the EGR, although I did unbolt it from the engine and pull the tube out of the intake so I could bend the line to the header easier. The AIR tube on the pass side does provide a little interference to change the #4 plug.
Yeah CT you can get it the codes tuned out to pass emissions. Thats what i gotta do my 98z i put a 04 Z06 motor in my car. I bought Pacesetter's LT's Race Style i took out my A/C, Air, and EGR so far its only showing 1 code thats for EGR. But so far i am only able to find 1 place here in CT that can tune cars thats EastSide Performance.
that's where the ss is going for the tune part, and my prob w/ the ps lt's was the wrong year tsp sent me, where in ct are you?
i'm from West Haven i live like 10-15 mins from EastSide Performance. Hey CT if i plug my EGR in would i still get a code for EGR? i am only getting 1 code from the PCM and thats for EGR can i plug it in and not have any problems with the SES light so i can go to emissions?
