ls2 tb conversion
Old 08-29-2005, 06:26 PM
what a rush!
moregrip's Avatar
Default ls2 tb conversion
anyone making a plug-n-play ls2 to ls6 tb conversion yet?
Old 08-29-2005, 06:39 PM
Brandon Boomhauer's Avatar
howell-efi.com
just saw it in the newest gm high tech
Old 08-30-2005, 05:21 PM
WILWAXU's Avatar
Are you talking LS2 tb on a LS1/6? Vette or F-body?
Old 08-30-2005, 07:22 PM
what a rush!
moregrip's Avatar
I'm talking using the 90mm tb in place of the LS1/6 tb. I was wondering if someone had a plug n play wiring adapter mainly, and maybe a tb spacer/adapter due to the different bolt pattern.
Old 08-30-2005, 09:25 PM
WILWAXU's Avatar
TPiS has a couple different setups that they sell using their own modifed intakes and TB's. They are the only one's that I know of with a direct "plug-n-play" setup to a LS6 intake.
If you are using a aftermarket 90mm TB (Nick Williams, FAST, etc..) you should be able to use the standard connections for a car setup. They plug directly into the car harness, but of course you will need to make some sort of adapter.
I'm guessing by your signature that you are trying to adapted one for you Radix kit. Haven't seen anything that would be a direct fit.
Old 08-30-2005, 11:18 PM
what a rush!
moregrip's Avatar
thanks
exactly. how do the Nick Williams or Fast tb compare to a stock tb with regard to idle?
Old 08-31-2005, 07:46 PM
WILWAXU's Avatar
Nick Williams is a member here. You might want to contact him to see if he is interested in helping with your project. Send a private message to Nick Williams
Old 09-01-2005, 12:16 AM
what a rush!
moregrip's Avatar
thanks, sent him a pm
