LS2 intake manifold
Old 09-12-2005, 11:27 AM
BEANSAW's Avatar
Default LS2 intake manifold
Will the LS2 intake manifold fit on an LS1 engine? I realize it would take a different sized throttle body, but are the dimensions correct for fitment. Also, if it does fit does anyone know if it is more efficient than the LS6 intake manifold. Or would the LS6 or the LSX still be the way to go.
Old 09-12-2005, 12:52 PM
Bad30th's Avatar
Search holds the answers you seek...
- yes it bolts right up to LS1/LS6 heads
- you need new LS2 fuel rails since the LS1 rails won't fit
- need new 90mm LS2 TB or aftermarket
- does not gain any power over LS6 intake on an LS1/LS6 setup
Cheers,
Bad30th
Old 09-12-2005, 12:58 PM
zombie1's Avatar
2nd that!
Old 09-12-2005, 01:13 PM
iamsickofitall's Avatar
i think some people have lost power going from an LS6 to LS2 intake swap, actually
Old 09-12-2005, 01:20 PM
Redneck Z's Avatar
It does fit, with modification and a new TB. You might not gain anything over your LS1 intake though. The LS2 is a crappy intake. If you want performance and an easy swap, just throw an LS6 intake on.
Old 09-12-2005, 03:59 PM
sixvi6-camaro's Avatar
somewhere on this board there are flow #'s between the FAST intake, LS6, and LS2 intakes on LS6 style heads. the LS2 intake flowed worse than the LS6 intake.
Old 09-12-2005, 04:02 PM
DarknessC5's Avatar
Could you put the LS2 throttle body on an LS6 intake?
Old 09-12-2005, 04:09 PM
Redneck Z's Avatar
No, the best you can do is a ported stocker. If you go any bigger than stock, the TB will be bigger than the intake opening, causing turbulance.
Old 09-12-2005, 11:35 PM
jrp
SN95 Director
jrp's Avatar
i wonder where they could be
