Header Question
Header Question
Looking to pick up some long tubes for my ls1, i will not be running cats anymore, so do i need to buy an ORY or will the pacesetters bolt to the stock exhaust system? tried search but coudnt find a defenetive answer
SSU's Drunk Typing Whore
Yep you will need an ORY if you want to delete the cats. When you get the ORY you will need to run either o2 sims or get the code deleted by LS1edit or HPtuners. Also make sure that emissions is not a concern for you, if it is not then an ORY is perfect for ya.
