If you get a cut-out what's the point of ....
Old 09-18-2005, 11:36 PM
ebear's Avatar
Default If you get a cut-out what's the point of ....
If I plan on getting a cut-out, what is the point of getting aftermarket exhaust? (besides headers)
Old 09-18-2005, 11:48 PM
BrandonDrecksage's Avatar
better flow...not all of the exhaust goes out of the cutout..not to mention the bottle next of a stock y pipe before the cutout...and also good performance while cut out is shut
Old 09-18-2005, 11:49 PM
SUX2BU's Avatar
So you can have loud and LOUDER.
Old 09-18-2005, 11:50 PM
ebear's Avatar
Oh, sorry, I meant exhaust AFTER the cutout. I'm just trying to see if it would be worth the money to get exhaust. Also, True Duals > Cutout??
EDIT
found my answer in the sticky
Exhaust Systems:
While there is A LOT of bullshit that flies around the Internet about "this exhaust sounds better then that one", this post is not for posers who want to whine about rasp. The very best-flowing exhaust there is, is a true dual X-pipe or H-pipe setup, with or without bullet mufflers. The next best thing is a cutout in the I-pipe. No cat-back out-flows a cutout; no Y-pipe setup out-flows true duals. Period.
So I guess, I'll get the cut-out since it's cheap, and get duals once I replace the headers.
Old 09-19-2005, 07:43 AM
Order 66's Avatar
EDIT
Exhaust Systems:
Where is your data that no y pipe out flows true duals? Also how come Nascar runs a y pipe and not an X pipe. So dont state soemthing you dont have facts on.
Old 09-19-2005, 10:29 AM
ebear's Avatar
Hey, DONT start talking **** to me, that info is off the sticky on this website.
Old 09-19-2005, 10:38 AM
ebear's Avatar
and also to defend the creator of the sticky
the sticky is about f-bodies, nascar isn't using f bodies, therefore the advice does not apply to them, read the whole post before you respond to it.
Old 09-19-2005, 10:43 AM
monicaz28's Avatar
True duals definitely flow better, but you will like the cutout as well...I just love how it sounds.
Old 09-19-2005, 12:26 PM
bowtieman81's Avatar
Brandon is right, not all exhaust will go out the cutout, this is from my own experience. And, a y-pipe can be a bottleneck, but different y-pipes vary as to restriction.
Old 09-19-2005, 12:33 PM
35thZ-28's Avatar
You make a great point. I have been wondering the same thing. I dont want to get a $500 catback when I can get a $150 electric cutout w/ more flow and better sound. It is driving me nuts because either everyone on this site has more money than i do or they know something i dont! **** it, I'm getting a cutout!
Old 09-19-2005, 12:39 PM
VSJ
VSJ's Avatar
Just be like me and get a $35 3" cutout and leave it open all the time.
Old 09-19-2005, 12:43 PM
35thZ-28's Avatar
does it sound bad ***? how quick can you cap/uncap it?
Old 09-19-2005, 12:50 PM
98Z28MASS's Avatar
On a stock exhuats a cut-out is gonna sound very similar to an SLP LM system if you put the cut-out in the I-pipe. I have heard a stock LS1 trans am with a cut-out and it sounded very similar to my car before I put on my headers. Its also real easy to cap and uncap but I say if your on stock manifolds and put it in the I-pipe you could run ti open all the time and it sounds real good. Good luck though with whatever you choose!
Old 09-19-2005, 01:20 PM
ebear's Avatar
Not getting the car until next year but I always wondered about it, I'm going to get a cut-out until a decide to swap headers then I'll just get true duals.
Now, is it worth it to get dual cut-outs?
Old 09-19-2005, 01:35 PM
spy2520's Avatar
i dont think i'm going to do any catback stuff for a while now that i got my cutout.
Old 09-19-2005, 01:45 PM
sspower's Avatar
well IMO i liek the sound of my car with a hooker catback better than i like the sound of a cutout but i also have hooker headers and ORY. The catback kills rasp and drone well almost all of it and the cutout doesnt. Also People who have a cutout on a hooker muffler have not seen big gains with the cutout open versus closed. Which means the hooker muffler flows pretty well so im happy.
Old 09-19-2005, 02:53 PM
spy2520's Avatar
you know i think i lucked up because i have no drone even with headers and no cats and a cutout. When i had stock manifolds i had alot of drone, but now there is none. In my case, i'll gladly take the cutout over anything else soundwise, but i know alot of people have problems just like i did with stock manifolds and for that i understand how alot of people would rather have their catback than listen to the cutout.
Old 09-19-2005, 05:09 PM
Ryan02SS's Avatar
If I could start modding my car all over I would just have bought an electric cutout and be done with it. Use the money saved for better go fast goodies.
As to the TD's vs Y setup........ Mike Kleman of Rapid Motorsports has the fastest NA LS1 in the country and he personally told me he switched from TD's to a Y pipe setup. FWIW
Old 09-19-2005, 05:32 PM
Phoenix 5.7's Avatar
one reason that a normal y pipe system doesn't perform as well as a dual system is the shear size of the piping. a y pipe system is usually 3in, at most 4in. with TDs it is usually 2.5 or 3in per pipe so that is like having double the pipe. now 3 in isn't usually needed on a TD setup, but 3 in on a y setup can quickly become a restriction. and some TD systems have actually dynoed higher than a dual cutout due to the scavenging effect of the X pipe(i don't have the dyno charts, but i have seen it)
Old 09-19-2005, 06:22 PM
SiL3NtXWS6's Avatar
so, are dual cutouts in the Y pipe going to outflow true duals?
