Vic jr/GMPP Carb Valley cover
What lifter valley cover are the carb setup guys using?
Are you just using the LS1 or 6 over and removing the knock sensors? Is there a flat plate cover?
I am running a vacuum pump setup so I dont want or need a breather I just need a solid lifter valley cover.
Any help is appreciated.
Mike
Mike
you can use the ls1 or 6 valley. the intakes are cut to miss the bolt heads.
WAR (wagner) has a sheet metal cover out with a stack in front for a breather.
its bad ***.
if i ever pull my intake, im gonna get one for the breather purposes.
then ill put my oil cap back on.
its bad ***.
WAR sheet metal cover
its bad ***.
its bad ***.
Hey TJ,
Were can I find some info on this sheet metal cover? I've been looking for a while and haven't found anything. Any help would be appreciated.
Thanks,
Rich
Originally Posted by RC04SS
Hey TJ,
Thanks,
Rich
Thanks,
Rich
they come way down in price. even comes with a filter now.
im gonna have to go ahead and get one.
http://s41657.sites80.storefront-hos...l.aspx?ID=3287
good luck!
